Aller au contenu principal
Dell Inspiron 13-7353 Battery Replacement
Andrew Parkhurst
Andrew Parkhurst et 4 autres contributeurs
Dernière mise à jour le November 19, 2020
5 - 10 minutes
Très facile
If the Dell Inspiron 13-7353 is experiencing a corrupted battery, short battery life, physical damage, or any problems requiring the battery to be replaced, use the guide below to replace the battery.
Ensure the battery is still experiencing problems before working on the components.
Before working on the device, power down the computer and clear all debris once the back of the device has been opened.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dell Inspiron 13-7353 Battery Replacement, Battery: étape 1, image 1 de 1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Battery Replacement: étape 3, image 1 de 1
    • Remove the battery up and out of the computer.
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 23
Total : 1,136
