Aller au contenu principal
Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement
Bo Yi Lim
Bo Yi Lim et un autre contributeur
Dernière mise à jour le June 27, 2019
10 - 20 minutes
Modérée
A besoin de meilleures images
Use this guide to replace your USB/SD Card Reader IO Circuit Board. You will need a Phillips #0 screwdriver and a plastic opening tool to complete this guide.
Ce dont vous avez besoin
Outils
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Battery: étape 1, image 1 de 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 2, image 1 de 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 3, image 1 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 3, image 2 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 3, image 3 de 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 4, image 1 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 4, image 2 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 4, image 3 de 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Hard Drive: étape 5, image 1 de 1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  6. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 6, image 1 de 2 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 6, image 2 de 2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
  7. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, WLAN Adaptor: étape 7, image 1 de 1
    • Unhook both of the wires attached to the WLAN adaptor.
  8. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 8, image 1 de 1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  9. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 9, image 1 de 1
    • Gently remove the WLAN adaptor.
  10. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, USB/SD Card Reader IO Circuit Board: étape 10, image 1 de 1
    • Using the plastic opening tool, unhook the black cable as shown.
  11. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 11, image 1 de 1
    • Gently pull to unplug the speaker cable.
  12. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 12, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the 3.9mm Phillips screw as shown.
  13. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: étape 13, image 1 de 1
    • Gently raise the USB/SD Card Reader IO Circuit Board and pull the part free from the device.
Bo Yi Lim
Membre depuis le 04/02/19
205 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G4, Harley Spring 2019 Membre de l'équipe IUPUI, Team S3-G4, Harley Spring 2019
IUPUI-HARLEY-S19S3G4
3 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 374
