Aller au contenu principal
Dell Inspiron 1320 Memory Module Replacement
Terrence15
Terrence15 et 2 autres contributeurs
Dernière mise à jour le November 14, 2019
30 secondes - 2 minutes
Très facile
Conditions préalables manquantes
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Memory Module.
  1. Dell Inspiron 1320 Memory Module Replacement, Popping up the Memory Module: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Dell Inspiron 1320 Memory Module Replacement, Removing the Memory Module: étape 2, image 1 de 2 Dell Inspiron 1320 Memory Module Replacement, Removing the Memory Module: étape 2, image 2 de 2
    • Remove the memory module from the memory module connector.
  3. Dell Inspiron 1320 Memory Module Replacement, Align the Notch: étape 3, image 1 de 1
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  4. Dell Inspiron 1320 Memory Module Replacement, Sliding the Memory Module: étape 4, image 1 de 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Terrence15
Membre depuis le 12/18/17
79 585 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 135
