Aller au contenu principal
Dell Inspiron 13z N301z Display Assembly Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 14, 2019
5 - 7 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 13z N301z Display Assembly Replacement, Disconnecting the Antenna Cables: étape 1, image 1 de 1
    • Follow the instructions in Before You Begin.
    • Turn the computer over.
    • Disconnect the Mini-Card antenna cables from the computer base.
  2. Dell Inspiron 13z N301z Display Assembly Replacement, Opening the Display: étape 2, image 1 de 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 13z N301z Display Assembly Replacement, Disconnecting the Display Cable: étape 3, image 1 de 1
    • Disconnect the display cable and the camera cable from their connectors on the system board.
  4. Dell Inspiron 13z N301z Display Assembly Replacement, Removing the Cables: étape 4, image 1 de 1
    • Make a note of the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
  5. Dell Inspiron 13z N301z Display Assembly Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 13z N301z Display Assembly Replacement, Removing the Display Assembly: étape 6, image 1 de 1
    • Lift and remove the display assembly off the computer base.
  7. Dell Inspiron 13z N301z Display Assembly Replacement, Placing the Display Assembly: étape 7, image 1 de 2 Dell Inspiron 13z N301z Display Assembly Replacement, Placing the Display Assembly: étape 7, image 2 de 2
    • Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron 13z N301z Display Assembly Replacement, Routing the Antenna Cables: étape 8, image 1 de 1
    • Route the Mini-Card antenna cables through the slot on the computer base.
  9. Dell Inspiron 13z N301z Display Assembly Replacement, Connecting the Cables: étape 9, image 1 de 1
    • Connect the display cable and the camera cable to their connectors on the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 6
Total : 158
