Aller au contenu principal
Dell Inspiron 13z N311z Memory Modules Replacement
Terrence15
Terrence15 et 2 autres contributeurs
Dernière mise à jour le November 14, 2019
25 secondes - 1 minute
Très facile
Conditions préalables manquantes
Tutoriel réalisé par la communauté
In this guide, we will show you how to remove and replace the Memory Modules.
  1. Dell Inspiron 13z N311z Memory Modules Replacement, Popping up the Memory Module: étape 1, image 1 de 2 Dell Inspiron 13z N311z Memory Modules Replacement, Popping up the Memory Module: étape 1, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Dell Inspiron 13z N311z Memory Modules Replacement, Removing the Memory Module: étape 2, image 1 de 2 Dell Inspiron 13z N311z Memory Modules Replacement, Removing the Memory Module: étape 2, image 2 de 2
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 13z N311z Memory Modules Replacement, Align the Notch: étape 3, image 1 de 2 Dell Inspiron 13z N311z Memory Modules Replacement, Align the Notch: étape 3, image 2 de 2
    • Align the notch on the NEW memory module with the tab in the memory module connector.
  4. Dell Inspiron 13z N311z Memory Modules Replacement, Sliding the Memory Module: étape 4, image 1 de 1
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down on both sides until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 86
