Aller au contenu principal
Dell Inspiron 14 7447 Display Assembly Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 13, 2019
15 - 40 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the Display Cable: étape 1, image 1 de 2 Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the Display Cable: étape 1, image 2 de 2
  2. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Cable: étape 2, image 1 de 1
    • Note the display cable routing and remove the cable from its routing guide.
  3. Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the Antenna Cables: étape 3, image 1 de 1
    • Disconnect the antenna cables from the wireless card.
  4. Dell Inspiron 14 7447 Display Assembly Replacement, Peeling the Tape: étape 4, image 1 de 1
    • Peel off the tape that secures the antenna cables to the speaker.
  5. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Cables: étape 5, image 1 de 1
    • Note the antenna cable routing and remove the cables from their routing guide.
  6. Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the I/O Board Cable: étape 6, image 1 de 1
    • Using the pull-tab, disconnect the I/O-board cable from the I/O board.
  7. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Cable: étape 7, image 1 de 1
    • Note the I/O-board cable routing and remove the cable from its routing guide.
  8. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Screws: étape 8, image 1 de 1
    • Remove the screws that secure the display assembly to the computer base.
  9. Dell Inspiron 14 7447 Display Assembly Replacement, Lifting the Display Assembly: étape 9, image 1 de 1
    • Lift the display assembly off the computer base.
  10. Dell Inspiron 14 7447 Display Assembly Replacement, Placing the Display Assembly: étape 10, image 1 de 1
    • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 7447 Display Assembly Replacement, Replace the Screws: étape 11, image 1 de 1
    • Replace the screws that secure the display assembly to the computer base.
  12. Dell Inspiron 14 7447 Display Assembly Replacement, Routing the I/O Board Cable: étape 12, image 1 de 1
    • Route the I/O-board cable through the routing guides on the computer base.
  13. Dell Inspiron 14 7447 Display Assembly Replacement, Connecting the I/O Board Cable: étape 13, image 1 de 1
    • Connect the I/O-board cable to the I/O board.
  14. Dell Inspiron 14 7447 Display Assembly Replacement, Routing the Antenna Cables: étape 14, image 1 de 1
    • Route the antenna cables through the routing guides on the computer base.
  15. Dell Inspiron 14 7447 Display Assembly Replacement, Adhering the Tape: étape 15, image 1 de 1
    • Adhere the tape securing the antenna cables to the speaker.
  16. Dell Inspiron 14 7447 Display Assembly Replacement, Connecting the Antenna Cables: étape 16, image 1 de 1
    • Connect the antenna cables to the wireless card.
  17. Dell Inspiron 14 7447 Display Assembly Replacement, Routing the Display Cable: étape 17, image 1 de 1
    • Route the display cable through the routing guides on the computer base.
  18. Dell Inspiron 14 7447 Display Assembly Replacement, Connecting the Display Cable: étape 18, image 1 de 1
    • Connect the display cable to the system board and adhere the tape.
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 11
Total : 1,044
