Aller au contenu principal
Dell Inspiron 14 7460 Memory Modules Replacement
Terrence15
Terrence15 et 2 autres contributeurs
Dernière mise à jour le November 14, 2019
45 secondes - 3 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will show you how to remove and replace the Memory Modules.
Ce dont vous avez besoin
  1. Dell Inspiron 14 7460 Memory Modules Replacement, Disconnecting the Battery Cable: étape 1, image 1 de 1
  2. Dell Inspiron 14 7460 Memory Modules Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  3. Dell Inspiron 14 7460 Memory Modules Replacement, Lifting the Battery: étape 3, image 1 de 1
    • Lift the battery off the palm rest and keyboard assembly.
    • Press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 14 7460 Memory Modules Replacement, Align the Screw Holes: étape 5, image 1 de 1
    • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
  5. Dell Inspiron 14 7460 Memory Modules Replacement, Replace the Screws: étape 6, image 1 de 1
    • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  6. Dell Inspiron 14 7460 Memory Modules Replacement, Connecting the Battery Cable: étape 7, image 1 de 1
    • Connect the battery cable to the system board.
  7. Dell Inspiron 14 7460 Memory Modules Replacement, Popping up the Memory Module: étape 8, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  8. Dell Inspiron 14 7460 Memory Modules Replacement, Removing the Memory Module: étape 9, image 1 de 1
    • Remove the memory module from the memory-module slot.
  9. Dell Inspiron 14 7460 Memory Modules Replacement, Align the Notch: étape 10, image 1 de 1
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  10. Dell Inspiron 14 7460 Memory Modules Replacement, Sliding the Memory Module: étape 11, image 1 de 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 715
