Aller au contenu principal
Dell Inspiron 14-3452 Motherboard Replacement
Meg Allison
Meg Allison et 3 autres contributeurs
Dernière mise à jour le May 4, 2018
35 - 45 minutes
Modérée
The motherboard functions as a central part of the laptop. Replacing the motherboard with a new one is an involved process, so we will walk you through each step of the process. All the tools needed is a screwdriver and a plastic spudger. Tweezers are optional.
Ce dont vous avez besoin
Outils
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Dell Inspiron 14-3452 Motherboard Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 14-3452 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Motherboard Replacement, Random Access Memory (RAM): étape 2, image 1 de 1
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Motherboard Replacement: étape 3, image 1 de 1
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Motherboard Replacement: étape 4, image 1 de 1
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Motherboard Replacement: étape 5, image 1 de 1
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
  6. Dell Inspiron 14-3452 Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
    • Remove the one Phillips Head 3 mm #0 screw from the computer backing.
  7. Dell Inspiron 14-3452 Motherboard Replacement: étape 7, image 1 de 2 Dell Inspiron 14-3452 Motherboard Replacement: étape 7, image 2 de 2
    • Remove the white and black antenna cables from the wireless card.
  8. Dell Inspiron 14-3452 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
  9. Dell Inspiron 14-3452 Motherboard Replacement: étape 9, image 1 de 1
    • Slide the wireless card out of the wireless card bay.
  10. Dell Inspiron 14-3452 Motherboard Replacement: étape 10, image 1 de 2 Dell Inspiron 14-3452 Motherboard Replacement: étape 10, image 2 de 2
    • Using your fingertips remove the speaker cable from the motherboard by pulling the white connector away from the socket.
  11. Dell Inspiron 14-3452 Motherboard Replacement: étape 11, image 1 de 1
    • Pry apart keyboard assembly slowly as keyboard cable will still be attached to the motherboard.
    • Use the blue spudger to pry apart the keyboard assembly from the bottom shell.
  12. Dell Inspiron 14-3452 Motherboard Replacement: étape 12, image 1 de 1
    • Disconnect the keyboard cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
  13. Dell Inspiron 14-3452 Motherboard Replacement: étape 13, image 1 de 2 Dell Inspiron 14-3452 Motherboard Replacement: étape 13, image 2 de 2
    • Remove the I/O board cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
  14. Dell Inspiron 14-3452 Motherboard Replacement: étape 14, image 1 de 1
    • Remove the three Phillips Head 5 mm #0 screws.
    • Remove the one Phillips Head 3 mm #0 screw.
  15. Dell Inspiron 14-3452 Motherboard Replacement: étape 15, image 1 de 2 Dell Inspiron 14-3452 Motherboard Replacement: étape 15, image 2 de 2
    • Disconnect the display cable from the motherboard by pulling tape back and lifting connector latch.
    • Pull the display cable away from the motherboard.
  16. Dell Inspiron 14-3452 Motherboard Replacement: étape 16, image 1 de 1
    • Remove the power adapter cable from the motherboard by sliding the cable out of its socket.
  17. Dell Inspiron 14-3452 Motherboard Replacement: étape 17, image 1 de 1
    • Lift the motherboard off of the computer base.
  18. Dell Inspiron 14-3452 Motherboard Replacement: étape 18, image 1 de 2 Dell Inspiron 14-3452 Motherboard Replacement: étape 18, image 2 de 2
    • Remove the four Phillips Head 3 mm #0 screws from the fan.
    • Remove the fan cable from the motherboard by sliding the cable out of the socket.
    • Lift the fan off of the motherboard.
Meg Allison
Membre depuis le 01/30/18
397 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team S2-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 membres
5 tutoriels rédigés
3 commentaires
BEFORE REMOVING TOP CASE: There are screws under the keyboard and one silver screw under the battery that have to be removed. This guide forgot to mention that.
Michael Hill - Réponse
Hello.
 Do you know how to expand the HDD memory of this same model 14-3452 ??;  I have a motherboard similar to the one in this guide and it does not have the connector for the hard disk integrated into it.
 I will greatly appreciate your help and response.
Lloyd Lopez -
Can the inspiron 15 3552 motherboard replace this model to have access to harddrive use?
kadianwilliams06 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 40
Total : 2,382
