Dell Inspiron 14-3452 Motherboard Replacement
Introduction
Passez à l'étape 1The motherboard functions as a central part of the laptop. Replacing the motherboard with a new one is an involved process, so we will walk you through each step of the process. All the tools needed is a screwdriver and a plastic spudger. Tweezers are optional.
Ce dont vous avez besoin
Remove the battery by sliding the battery release latch to the left.
Pull the entire battery away from the backing.
Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
Remove the one Phillips Head 3 mm #0 screw from the computer backing.
3 commentaires
BEFORE REMOVING TOP CASE: There are screws under the keyboard and one silver screw under the battery that have to be removed. This guide forgot to mention that.
Hello.
Do you know how to expand the HDD memory of this same model 14-3452 ??; I have a motherboard similar to the one in this guide and it does not have the connector for the hard disk integrated into it.
I will greatly appreciate your help and response.
Can the inspiron 15 3552 motherboard replace this model to have access to harddrive use?
