Aller au contenu principal
Dell Inspiron 14z-5423 RAM Replacement
Brittany
Brittany et 5 autres contributeurs
Dernière mise à jour le December 6, 2016
15 minutes
Facile
The RAM is a memory card that holds the operating system and applications in order for the computer to access data.
Ce dont vous avez besoin
  1. Dell Inspiron 14z-5423 RAM Replacement, RAM: étape 1, image 1 de 2 Dell Inspiron 14z-5423 RAM Replacement, RAM: étape 1, image 2 de 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 RAM Replacement: étape 2, image 1 de 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 RAM Replacement: étape 3, image 1 de 2 Dell Inspiron 14z-5423 RAM Replacement: étape 3, image 2 de 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 RAM Replacement: étape 4, image 1 de 2 Dell Inspiron 14z-5423 RAM Replacement: étape 4, image 2 de 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 14z-5423 RAM Replacement: étape 5, image 2 de 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
Brittany
Membre depuis le 09/12/16
917 Réputation
4 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-2, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 13
Total : 582
