Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Inspiron 15 7579 Speakers Replacement
Inaki Madrigal
Inaki Madrigal et 6 autres contributeurs
Dernière mise à jour le 7 mai 2024
10 - 15 minutes
Modérée
Tutoriel étudiant vedette
Before replacing the speakers, we recommend starting out with our troubleshooting guide. If you are still having problems, follow the steps below to replace your speakers.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 15 7579 Speakers Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Speakers Replacement: étape 2, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 2, image 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Speakers Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement, Battery: étape 3, image 2 de 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Speakers Replacement: étape 4, image 1 de 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
  5. Dell Inspiron 15 7579 Speakers Replacement, Speakers: étape 5, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement, Speakers: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • After battery is removed, locate the left and right speakers.
    • On the right speaker assembly, remove the pin connector using the tweezers.
  6. Dell Inspiron 15 7579 Speakers Replacement: étape 6, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 6, image 2 de 2
    • Use the metal spudger to pry off the right speaker assembly.
  7. Dell Inspiron 15 7579 Speakers Replacement: étape 7, image 1 de 1
    • Use a metal spudger to pry off left speaker assembly.
  8. Dell Inspiron 15 7579 Speakers Replacement: étape 8, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 8, image 2 de 2
    • Un-thread the wire by removing them from under the plastic clamps. No tools are required for this step. Repeat for both sides.
  9. Dell Inspiron 15 7579 Speakers Replacement: étape 9, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 9, image 2 de 2
    • Pull the adhesive cable away from the metal backing and push the right speaker assembly under it.
    • Remove the Velcro holding the speaker wire and remove the speakers from the device.
Équipez-vous pour vos futures réparations
Voir tous les produits
Inaki Madrigal
Membre depuis le 04/23/18
775 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 26
Total : 1,363
