Aller au contenu principal
Dell Inspiron 15 M5030 Display Assembly Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 22, 2019
9 - 15 minutes
Modérée
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 15 M5030 Display Assembly Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the base of the computer.
  2. Dell Inspiron 15 M5030 Display Assembly Replacement, Open the Display: étape 2, image 1 de 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 15 M5030 Display Assembly Replacement, Disconnecting the Antenna Cable: étape 3, image 1 de 1
    • Make a note of the Wireless Mini-Card antenna cable routing and disconnect the Wireless Mini-Card antenna cable from the Wireless Mini- Card.
  4. Dell Inspiron 15 M5030 Display Assembly Replacement, Disconnect the Display Cable: étape 4, image 1 de 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  5. Dell Inspiron 15 M5030 Display Assembly Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 15 M5030 Display Assembly Replacement, Removing the Display Assembly: étape 6, image 1 de 1
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron 15 M5030 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 1 de 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron 15 M5030 Display Assembly Replacement, Routing the Display Cable: étape 8, image 1 de 1
    • Route the display cable into the routing guide and connect the display cable to the connector on the system board.
  9. Dell Inspiron 15 M5030 Display Assembly Replacement, Routing the Cable: étape 9, image 1 de 1
    • Route the Mini-Card antenna cable into the routing guide and connect the Mini-Card antenna cable to the connector on the Mini-Card.
  10. Dell Inspiron 15 M5030 Display Assembly Replacement, Replace the Screws: étape 10, image 1 de 1
    • Turn the computer over and replace the two screws at the base of the computer.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 122
