Aller au contenu principal
Dell Inspiron 15-3542 LCD Screen Replacement
Najeemdeen Lamidi
Najeemdeen Lamidi et un autre contributeur
Dernière mise à jour le December 14, 2020
5 minutes
Facile
In this guide, you will learn how to replace a Dell Inspiron 15-3542 LCD.
The screen on a laptop serves as an output device for the operating system. One of the ways that a screen is damaged is when you see multiple color lines on the screen. The most common cause of screen damage occurs from dropping the laptop. Applying too much pressure on the screen will also cause the screen to break. Therefore, always make sure your laptop screen is handled with care.
Ce dont vous avez besoin
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: étape 1, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: étape 1, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: étape 1, image 3 de 3
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: étape 2, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 2, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 2, image 3 de 3
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: étape 3, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 3, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 3, image 3 de 3
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: étape 4, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 4, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 4, image 3 de 3
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Najeemdeen Lamidi
Membre depuis le 09/19/20
130 Réputation
1 tutoriel rédigé
Équipe
York University, Team S3-G48, Melo-Thaiss Fall 2020 Membre de l'équipe York University, Team S3-G48, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G48
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 1,186
