Dell Inspiron 15-5548 Battery Replacement
Introduction
Passez à l'étape 1This is a guide to show you how to replace the Dell Inspiron 15-5548 battery. Make sure that the laptop is unplugged and powered off before beginning this procedure.
Ce dont vous avez besoin
Look on the bottom of the computer. Locate the 2 screws. (Picture 1)
Using the Phillips 00 Screwdriver, unscrew both screws, and remove the bottom cover. The bottom cover can be hard to pull off, so you may need to pry it off with a pry tool.
To reassemble your device and add in a new battery, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
