Aller au contenu principal
Dell Inspiron 15-7547 Battery Replacement
Claro
Claro et 4 autres contributeurs
Dernière mise à jour le January 17, 2022
6 - 10 minutes
Modérée
This guide shows how to replace your Dell Inspiron 15-7547's battery.
Ce dont vous avez besoin
Kit de réparation
Ce kit contient toutes les pièces et tous les outils nécessaires à la réalisation de ce tutoriel.
Pièces
Outils
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Afficher plus…
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: étape 2, image 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 15-7547 Battery Replacement, Battery: étape 3, image 2 de 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7547 Battery Replacement: étape 4, image 2 de 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: étape 5, image 1 de 3 Dell Inspiron 15-7547 Battery Replacement: étape 5, image 2 de 3 Dell Inspiron 15-7547 Battery Replacement: étape 5, image 3 de 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Claro
Membre depuis le 09/10/18
591 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 27
Total : 2,222
