Aller au contenu principal
Dell Inspiron 15-7559 SSD Replacement
Trenton Greevebiester
Trenton Greevebiester et 3 autres contributeurs
Dernière mise à jour le December 29, 2017
5 - 10 minutes
Facile
How to replace the SSD for the Dell Inspiron 15-7559
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 15-7559 SSD Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 SSD Replacement: étape 2, image 1 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 2, image 2 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 2, image 3 de 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 SSD Replacement: étape 3, image 1 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 3, image 2 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 3, image 3 de 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 SSD Replacement, SSD: étape 4, image 1 de 1
    • Locate the SSD, it is located in the center on the far left.
  5. Dell Inspiron 15-7559 SSD Replacement: étape 5, image 1 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 5, image 2 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 5, image 3 de 3
    • Unscrew the 3mm Philips #1 screw that is holding the SSD in place.
  6. Dell Inspiron 15-7559 SSD Replacement: étape 6, image 1 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 6, image 2 de 3 Dell Inspiron 15-7559 SSD Replacement: étape 6, image 3 de 3
    • Gently pull out the SSD, horizontally along the computer to remove it.
5 autres ont terminé cette réparation.
Membre depuis le 10/19/17
1 614 Réputation
6 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G2, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 membres
9 tutoriels rédigés
1 commentaire de tutoriel
It would be helpful to know what types of SSD are supported. I’ve looked through the service manuals, and it doesn’t list what type it is. Some comments on other sites have implied it MUST be a SATA drive, not NVME, but more information than that is still hard to get (and I’m not completely certain the fact I list is correct, either…).
Russell Andres - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 32
Total : 4,235
