Dell Inspiron 1525 LCD Replacement
Introduction
Passez à l'étape 1Use this guide to help you replace the LCD on a Dell Inspiron 1525.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Remove the two 4.00 mm Phillips #1 screws from the battery tray.
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
Gently slide the keyboard towards the display until the tabs on its front side are free.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Disconnect the five antennas from their respective cards.
De-route the antennas from their routing retainers.
Use the pointed side of a spudger to peel the six small rubber feet off the display assembly.
Remove the six 6.05 mm Phillips #1 screws hidden beneath each of the rubber feet.
15 autres ont terminé cette réparation.
