Aller au contenu principal
Dell Inspiron 1526 Screen Replacement
Ahmed Alshamsi
Ahmed Alshamsi et 3 autres contributeurs
Dernière mise à jour le December 23, 2019
45 minutes
Difficile
The screen is an essential piece of hardware that, due to its delicate and large profile, is often damaged. In this guide, we will show you how to replace the screen on the Dell Inspiron 1526 Laptop.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 1526 Screen Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 1526 Screen Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 1526 Screen Replacement, Battery: étape 1, image 3 de 3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Screen Replacement, Keyboard: étape 2, image 1 de 1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Screen Replacement: étape 3, image 1 de 1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Screen Replacement: étape 4, image 1 de 1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Screen Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Screen Replacement: étape 6, image 1 de 2 Dell Inspiron 1526 Screen Replacement: étape 6, image 2 de 2
    • Remove the control cover.
  7. Dell Inspiron 1526 Screen Replacement: étape 7, image 1 de 1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Screen Replacement: étape 8, image 1 de 1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Screen Replacement: étape 9, image 1 de 2 Dell Inspiron 1526 Screen Replacement: étape 9, image 2 de 2
    • Remove the keyboard.
  10. Dell Inspiron 1526 Screen Replacement, Screen: étape 10, image 1 de 2 Dell Inspiron 1526 Screen Replacement, Screen: étape 10, image 2 de 2
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Screen Replacement: étape 11, image 1 de 3 Dell Inspiron 1526 Screen Replacement: étape 11, image 2 de 3 Dell Inspiron 1526 Screen Replacement: étape 11, image 3 de 3
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Screen Replacement: étape 12, image 1 de 2 Dell Inspiron 1526 Screen Replacement: étape 12, image 2 de 2
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
Ahmed Alshamsi
Membre depuis le 09/17/19
181 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 29
Total : 238
