Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Inspiron 3537 RAM Replacement
Shazil Mutahir
Shazil Mutahir et un autre contributeur
Dernière mise à jour le 16 juin 2022
3 - 5 minutes
Facile
This guide demonstrates how to replace the RAM on a Dell Inspiron 3537 Laptop with ease. The laptop comes stock with two RAM slots, which are already occupied. The RAM sticks are identified as: PC3L-12800 4 GB DDR3 RAM. Also, for the two RAM sticks to be compatible with each other, you have to use the same type of RAM stick as those that are already installed.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dell Inspiron 3537 RAM Replacement, RAM: étape 1, image 1 de 3 Dell Inspiron 3537 RAM Replacement, RAM: étape 1, image 2 de 3 Dell Inspiron 3537 RAM Replacement, RAM: étape 1, image 3 de 3
    • Use a Phillips #0 screwdriver to loosen the two 3 mm captive screws holding the tray in place.
    • The screws cannot be fully removed and only need to be loosened. Do not attempt to remove the screws from the tray.
    • Lift the RAM tray up and off.
  2. Dell Inspiron 3537 RAM Replacement: étape 2, image 1 de 3 Dell Inspiron 3537 RAM Replacement: étape 2, image 2 de 3 Dell Inspiron 3537 RAM Replacement: étape 2, image 3 de 3
    • Gently pull the two silver arms away from the RAM until the RAM slightly lifts from the motherboard.
  3. Dell Inspiron 3537 RAM Replacement: étape 3, image 1 de 2 Dell Inspiron 3537 RAM Replacement: étape 3, image 2 de 2
    • Slide the RAM directly out of its slot.
  4. Dell Inspiron 3537 RAM Replacement: étape 4, image 1 de 3 Dell Inspiron 3537 RAM Replacement: étape 4, image 2 de 3 Dell Inspiron 3537 RAM Replacement: étape 4, image 3 de 3
    • Insert your new/replacement RAM stick(s) into the slot(s).
    • Gently push down on the RAM until it clicks into place.
  5. Dell Inspiron 3537 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 3537 RAM Replacement: étape 5, image 2 de 2
    • Replace the RAM tray.
    • Screw in the two 3 mm screws with a Phillips #0 screwdriver.
Enjoy your new RAM!
Équipez-vous pour vos futures réparations
Voir tous les produits
Shazil Mutahir
Membre depuis le 01/18/22
121 Réputation
1 tutoriel rédigé
Équipe
York University, Team P-22, O'Regan Winter 2022 Membre de l'équipe York University, Team P-22, O'Regan Winter 2022
YORK-O'REGAN-W22SPG22
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 16
Total : 1,019
