Aller au contenu principal
Dell Inspiron 7568 Trackpad Replacement Guide
Yash Samant
Yash Samant et 3 autres contributeurs
Dernière mise à jour le May 16, 2017
10 minutes
Modérée
By following the steps in this guide one should be able to replace the trackpad on your device (Dell Inspiron 7568)
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 7568 Trackpad Replacement Guide, Battery: étape 1, image 1 de 2 Dell Inspiron 7568 Trackpad Replacement Guide, Battery: étape 1, image 2 de 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Trackpad Replacement Guide: étape 2, image 1 de 2 Dell Inspiron 7568 Trackpad Replacement Guide: étape 2, image 2 de 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: étape 3, image 1 de 2 Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: étape 3, image 2 de 2
    • Unplug the speaker cable and remove the speakers
  4. Dell Inspiron 7568 Trackpad Replacement Guide: étape 4, image 1 de 2 Dell Inspiron 7568 Trackpad Replacement Guide: étape 4, image 2 de 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) holding the touchpad bracket
    • Remove the touchpad bracket
  5. Dell Inspiron 7568 Trackpad Replacement Guide: étape 5, image 1 de 3 Dell Inspiron 7568 Trackpad Replacement Guide: étape 5, image 2 de 3 Dell Inspiron 7568 Trackpad Replacement Guide: étape 5, image 3 de 3
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the touchpad ribbon cable free.
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the keyboard daughter board ribbon cable free.
  6. Dell Inspiron 7568 Trackpad Replacement Guide: étape 6, image 1 de 3 Dell Inspiron 7568 Trackpad Replacement Guide: étape 6, image 2 de 3 Dell Inspiron 7568 Trackpad Replacement Guide: étape 6, image 3 de 3
    • Remove the touchpad foil using a spudger or other ESD safe blunt-tip tool.
    • Unscrew & remove the three 2mm wafer screws holding the touchpad.
    • Remove the touchpad.
2 autres ont terminé cette réparation.
Yash Samant
Membre depuis le 02/22/17
406 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G2, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 6
Total : 381
