Aller au contenu principal
Dell Inspiron B130 Keyboard Replacement
Patrick McNeil
Patrick McNeil et 3 autres contributeurs
Dernière mise à jour le February 27, 2025
Aucune estimation
Modérée
Étudiant en action
This guide will show and tell you how to replace the keyboard. Your keyboard maybe broken if the keys do not work when you are typing. Please refer to our Troubleshooting page for more information.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron B130 Keyboard Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron B130 Keyboard Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron B130 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Keyboard Replacement: étape 2, image 1 de 3 Dell Inspiron B130 Keyboard Replacement: étape 2, image 2 de 3 Dell Inspiron B130 Keyboard Replacement: étape 2, image 3 de 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Keyboard Replacement: étape 3, image 1 de 3 Dell Inspiron B130 Keyboard Replacement: étape 3, image 2 de 3 Dell Inspiron B130 Keyboard Replacement: étape 3, image 3 de 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Put down the computer and open up the screen.
    • There is a long piece of plastic underneath the screen that you will have to remove.
  5. Dell Inspiron B130 Keyboard Replacement: étape 5, image 1 de 3 Dell Inspiron B130 Keyboard Replacement: étape 5, image 2 de 3 Dell Inspiron B130 Keyboard Replacement: étape 5, image 3 de 3
    • When you pry the plastic plate off, be careful and pry gently so you do not crack the plastic.
    • Insert the plastic opening tool into the little slot.
    • Lift up gently and remove the plastic cover.
  6. Dell Inspiron B130 Keyboard Replacement: étape 6, image 1 de 1
    • Remove the two 4mm screws at the top of the keyboard.
    • The keyboard is now loose but don't pull it out just yet. It is still connected underneath. Be gentle when lifting keyboard so you do not damage this connection.
  7. Dell Inspiron B130 Keyboard Replacement: étape 7, image 1 de 2 Dell Inspiron B130 Keyboard Replacement: étape 7, image 2 de 2
    • Lift keyboard up slightly and you will see the keyboard connection.
    • This black tab has to be lifted up to remove the keyboard.
    • Put your finger underneath the tab and pull back gently as indicated.
    • You can now remove the keyboard.
Patrick McNeil
Membre depuis le 10/19/16
937 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 229
