Aller au contenu principal
Dell Inspiron E1505 Modem Replacement
Ce dont vous avez besoin
  1. Dell Inspiron E1505 Modem Replacement, Battery: étape 1, image 1 de 1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Modem Replacement: étape 2, image 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Modem Replacement: étape 3, image 1 de 1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Modem Replacement: étape 4, image 1 de 1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
  5. Dell Inspiron E1505 Modem Replacement, Back Door removal: étape 5, image 1 de 1
    • On the back of the laptop there is a compartment for the modem for easy access.
    • It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
    • Unscrew the two screws with a screwdriver and lift the backplate up to unveil the Modem.
  6. Dell Inspiron E1505 Modem Replacement: étape 6, image 1 de 1
    • There are two metal tabs on each of the sticks of the modem.
    • Press each of the tabs outward and the modem stick should slide up.
    • Gently pull the stick of phone modem out and get the product number to get replacement modem.
    • Do this for both of the sticks of phone modem.
  7. Dell Inspiron E1505 Modem Replacement, Inserting a new modem: étape 7, image 1 de 1
    • Installing a new modem: Line up the new modem by making sure the slot where the modem is installed lines up with the position of the connector on the new modem.
    • Push the modem down. Make sure to do this evenly so the modem makes a good connection.
    • Repeat this procedure until the modem is secure.
Équipe
UMass Dartmouth, Team 6-7, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 membres
4 tutoriels rédigés
Un commentaire
That is not the wireless card. That is the phone modem. The wireless card is a mini PCI-e card located directly under the backspace key.
George A. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 493
