Aller au contenu principal
Dell Inspiron M531R-5535 Computer Battery Replacement
Anthony Castro
Anthony Castro et 3 autres contributeurs
Dernière mise à jour le December 28, 2022
2 minutes
Très facile
Use this guide to replace the battery in your Dell Inspiron M531R-5535 laptop.
A functional battery provides power to your laptop. Eventually, laptop batteries will rapidly drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual, consider calibrating your battery to determine an accurate charging capacity. If you continue to notice significant drops in battery percentage, you should replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
  1. Dell Inspiron M531R-5535 Computer Battery Replacement, Computer Battery: étape 1, image 1 de 1
    • Flip laptop over so the battery component is easily located.
  2. Dell Inspiron M531R-5535 Computer Battery Replacement: étape 2, image 1 de 2 Dell Inspiron M531R-5535 Computer Battery Replacement: étape 2, image 2 de 2
    • Slide the battery locks outwards to unlock the battery from the computer.
  3. Dell Inspiron M531R-5535 Computer Battery Replacement: étape 3, image 1 de 2 Dell Inspiron M531R-5535 Computer Battery Replacement: étape 3, image 2 de 2
    • Place hand over battery. Lift battery up. Pull away from laptop.
Anthony Castro
Membre depuis le 09/26/22
97 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 6-5, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 6-5, Adachi Fall 2022
CSULA-ADACHI-F22S6G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 7
Total : 275
