Aller au contenu principal
Dell Inspiron Mini 10 Keyboard Replacement
Danielle Jarecki
Danielle Jarecki et 3 autres contributeurs
Dernière mise à jour le December 22, 2016
5 minutes
Facile
This guide will take you through how to remove the keyboard for cleaning or replacing.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron Mini 10 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Keyboard Replacement: étape 2, image 1 de 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Keyboard Replacement: étape 4, image 1 de 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Keyboard Replacement: étape 5, image 1 de 2 Dell Inspiron Mini 10 Keyboard Replacement: étape 5, image 2 de 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Keyboard Replacement: étape 6, image 1 de 2 Dell Inspiron Mini 10 Keyboard Replacement: étape 6, image 2 de 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
Danielle Jarecki
Membre depuis le 10/21/16
334 Réputation
5 tutoriels rédigés
Équipe
UW Tacoma, Team 1-4, Rose Fall 2016 Membre de l'équipe UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 6
Total : 1,373
