Aller au contenu principal
Dell Inspiron N5030 Disc Drive Replacement
Charles
Charles et 2 autres contributeurs
Dernière mise à jour le June 10, 2014
15 minutes
Modérée
Tutoriel étudiant vedette
If your disk drive on your Dell Inspiron N5030 is not working, and you have tried the other options on the troubleshooting page, this guide will help you replace it with a new one.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron N5030 Disc Drive Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron N5030 Disc Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Disc Drive Replacement: étape 2, image 1 de 2 Dell Inspiron N5030 Disc Drive Replacement: étape 2, image 2 de 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Disc Drive Replacement, Keyboard: étape 3, image 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Disc Drive Replacement: étape 4, image 1 de 1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Disc Drive Replacement: étape 5, image 1 de 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Disc Drive Replacement: étape 6, image 1 de 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Disc Drive Replacement: étape 7, image 1 de 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Disc Drive Replacement: étape 8, image 1 de 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Disc Drive Replacement: étape 9, image 1 de 1
    • Remove the top keyboard panel.
  10. Dell Inspiron N5030 Disc Drive Replacement, Disc Drive: étape 10, image 1 de 1
    • Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
  11. Dell Inspiron N5030 Disc Drive Replacement: étape 11, image 1 de 1
    • Position your thumbs to push firmly and slide the disc drive to the right through the rectangular hole in the side of the laptop and out.
3 autres ont terminé cette réparation.
Charles
Membre depuis le 04/22/14
582 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-59, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 2,058
