Aller au contenu principal
Dell Latitude 3190 M.2 SSD Replacement
Daniel Tzunum
Daniel Tzunum et 5 autres contributeurs
Dernière mise à jour le January 9, 2025
15 - 30 minutes
Facile
If your Dell Latitude 3190 laptop is showing the black screen of death, taking a long time to startup or is slow to load applications, use this guide to replace or upgrade your M.2 SSD for the Dell Latitude.
An SSD is a solid-state drive that uses flash memory to store data in your computer. An SSD provides the computer with better performance and energy consumption.
The laptop’s SSD needs to be upgraded or replaced if the computer is lacking in performance or it is slow to startup and load.
Before starting this repair, power off your device and unplug from the charger.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Dell Latitude 3190 M.2 SSD Replacement, Base Cover: étape 1, image 1 de 2 Dell Latitude 3190 M.2 SSD Replacement, Base Cover: étape 1, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 M.2 SSD Replacement: étape 2, image 1 de 3 Dell Latitude 3190 M.2 SSD Replacement: étape 2, image 2 de 3 Dell Latitude 3190 M.2 SSD Replacement: étape 2, image 3 de 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: étape 3, image 1 de 3 Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: étape 3, image 2 de 3 Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: étape 3, image 3 de 3
    • Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
  4. Dell Latitude 3190 M.2 SSD Replacement: étape 4, image 1 de 3 Dell Latitude 3190 M.2 SSD Replacement: étape 4, image 2 de 3 Dell Latitude 3190 M.2 SSD Replacement: étape 4, image 3 de 3
    • Locate the M.2 SSD after the battery is removed
    • Use the Phillips #0 screwdriver to remove the 3 mm screw from the SSD.
    • Pull the M.2 SSD from the board.
Daniel Tzunum
Membre depuis le 09/01/21
235 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-5, Saknee Fall 2021 Membre de l'équipe Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 membres
9 tutoriels rédigés
1 commentaire de tutoriel
It's worth noting that some Latitude 3190s use eMMC storage, and these lack the M2 socket on the motherboard, although it would be possible to solder one on (the 80mm standoff and screw are present!)
Tim Walker - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 23
30 derniers jours : 108
Total : 4,365
