Dell Latitude E4200 SSD Replacement
Introduction
Passez à l'étape 1Follow these steps in order to successfully replace the SSD of your laptop.
Ce dont vous avez besoin
Outils
Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
6 autres ont terminé cette réparation.
Un commentaire
You can use any mSATA SSD as replacement by using the following caddy/adapter:
