Aller au contenu principal
Dell Latitude E5470 Screen Assembly  Replacement
Ethan Jones
Ethan Jones et 2 autres contributeurs
Dernière mise à jour le October 1, 2019
40 minutes
Modérée
Tutoriel réalisé par la communauté
When a problem exists with the display, wifi, camera, or even the laptop lid itself, it is often easier to just replace the whole screen assembly. This guide is a quick simple way to accomplish this task.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Latitude E5470 Screen Assembly  Replacement, Remove Bottom Cover: étape 1, image 1 de 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove Bottom Cover: étape 1, image 2 de 2
    • Loosen the 8 Philips screws on the bottom of the laptop. They will not come all the way out but loosen till they spin freely.
    • Use a splurger to slowly pry the bottom cover off the laptop. Pull the bottom off in the direction of the arrow.
    • Important Be carefull to not break the snaps as they are delicate.
  2. Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Battery: étape 2, image 1 de 1
    • Important Disconnect the battery before any work is done. Failure to do so could result in electric shock and cause harm to you and the laptop.
    • Carefully use the plastic tab to remove the battery cable from the motherboard.
  3. Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Wireless Card: étape 3, image 1 de 2 Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Wireless Card: étape 3, image 2 de 2
    • Unscrew the screw holding the card in place.
    • Remove the metal guard holding the connections in place.
    • Use the splurger to gently lift the wires from the card.
  4. Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Display: étape 4, image 1 de 2 Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Display: étape 4, image 2 de 2
    • Remove screw holding the metal plate in place.
    • Remove metal plate
    • Carefully pull on the tab to disconnect the display cable from the motherboard.
  5. Dell Latitude E5470 Screen Assembly  Replacement, Free display cables: étape 5, image 1 de 2 Dell Latitude E5470 Screen Assembly  Replacement, Free display cables: étape 5, image 2 de 2
    • Remove both screws holding the plate in place.
    • Remove plate
    • Remove tape holding the display cable to the laptop.
    • Pull the cable free
  6. Dell Latitude E5470 Screen Assembly  Replacement, Remove hinge covers: étape 6, image 1 de 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove hinge covers: étape 6, image 2 de 2
    • Remove both the screws and hing covers on the back of the device.
  7. Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 1: étape 7, image 1 de 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 1: étape 7, image 2 de 2
    • Remove two screws from the bottom of the device
  8. Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 2: étape 8, image 1 de 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 2: étape 8, image 2 de 2
    • Remove screws underneath the hinge covers on the back of the device
  9. Dell Latitude E5470 Screen Assembly  Replacement, Remove display: étape 9, image 1 de 1
    • Carefully remove the display from its slots.
    • Be mindful to feed the WiFi and Display cables through the holes.
  10. Dell Latitude E5470 Screen Assembly  Replacement, You are done!: étape 10, image 1 de 1
    • The display is now disconnected from the laptop.
5 autres ont terminé cette réparation.
Ethan Jones
Membre depuis le 07/16/18
542 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 2,957
