Aller au contenu principal
Dell Precision 5520 Memory Module Replacement
Johnathan Hammond
Johnathan Hammond et un autre contributeur
Dernière mise à jour le August 17, 2022
10 - 20 minutes
Facile
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Precision 5520 Memory Module Replacement, Base Cover: étape 1, image 1 de 2 Dell Precision 5520 Memory Module Replacement, Base Cover: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Memory Module Replacement, Battery: étape 2, image 1 de 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
  3. Dell Precision 5520 Memory Module Replacement, Memory Module: étape 3, image 1 de 1
    • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
Johnathan Hammond
Membre depuis le 02/28/18
45 237 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 20
Total : 1,401
