Aller au contenu principal
Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement
Hector
Hector et 5 autres contributeurs
Dernière mise à jour le March 26, 2024
5 minutes
Modérée
This guide shows how to replace NVMe expansion sticks on a Dell Precision 7560 laptop. You will need to pull gently.
Ce dont vous avez besoin
Outils
  1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): étape 1, image 1 de 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): étape 1, image 2 de 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): étape 1, image 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: étape 2, image 1 de 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: étape 2, image 2 de 2
    • Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
  3. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: étape 3, image 1 de 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: étape 3, image 2 de 2
    • Disconnect the left SSD stick by pulling its exposed end towards you.
    • Repeat the same procedure to the right SSD stick.
Hector
Membre depuis le 02/14/23
261 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-1, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-1, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G1
3 membres
6 tutoriels rédigés
1 commentaire de tutoriel
This is not for RAM this is for the SSD upgrades.
Kurtis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 34
Total : 531
