Aller au contenu principal
Dell Vostro V13 Disassembly
Kevin Dookharan
Kevin Dookharan et 7 autres contributeurs
Dernière mise à jour le September 14, 2020
20 minutes - 1 heure
Modérée
Photos d’action
Tutoriel réalisé par la communauté
Meilleure introduction
This guide explains how to remove/replace any part on a Dell Vostro V13 laptop by describing a complete tear-down. Any screwdriver of size PH00 to PH1 will work with the screws on this laptop.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: étape 1, image 1 de 3 Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: étape 1, image 2 de 3 Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: étape 1, image 3 de 3
    • Remove the two plastic dummy cards from the laptop.
    • Unscrew the six PH00 screws from the bottom of the laptop.
    • Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
    • Slide the bottom cover forward and lift it upwards to remove.
    • You may need to use a strong spudger to create a gap along the base edge - starting from the Ethernet port on the right toward the Kensington port on the left.
  2. Dell Vostro V13 Disassembly: étape 2, image 1 de 1
    • Carefully remove the battery connector. It is a ribbon cable that is clamped down. Flick the black clamp up using the edge nearest the battery. The ribbon cable is now free to move for the next step.
    • Unscrew the four PH00 screws from the battery.
    • Lift the battery upwards to remove it.
  3. Dell Vostro V13 Disassembly: étape 3, image 1 de 2 Dell Vostro V13 Disassembly: étape 3, image 2 de 2
    • Unscrew the four PH00 screws from the hard drive enclosure.
    • To remove the hard drive, gently lift the drive to a shallow upward angle and carefully slide it to the right.
    • To avoid damaging the SATA port, lift the hard drive to a very small angle while removing it!
  4. Dell Vostro V13 Disassembly: étape 4, image 1 de 2 Dell Vostro V13 Disassembly: étape 4, image 2 de 2
    • Using a plastic opening tool, pry open the top panel containing the power switch. Start with the bottom-right edge closest to the keyboard.
    • Unclip and remove the ribbon from the panel.
    • Always be careful when removing ribbon cables! Try not to bend them unnecessarily. Do not pull them with excess force.
    When you're prying this off it might resist a little more than you'd think it should near where it's held by 2 pressure clips near the center.
    Brett Hoop - Réponse
  5. Dell Vostro V13 Disassembly: étape 5, image 1 de 2 Dell Vostro V13 Disassembly: étape 5, image 2 de 2
    • Remove the two PH00 screws from the keyboard.
    • Gently lift the keyboard upwards and push it towards the screen to remove.
    • Remove the ribbon cable from underneath the keyboard.
  6. Dell Vostro V13 Disassembly: étape 6, image 1 de 2 Dell Vostro V13 Disassembly: étape 6, image 2 de 2
    • Remove all of the ribbon cables from the motherboard.
    • Take out the one screw from the audio card and then lift upward to remove.
  7. Dell Vostro V13 Disassembly: étape 7, image 1 de 2 Dell Vostro V13 Disassembly: étape 7, image 2 de 2
    • Unscrew the six PH00 screws from the memory card reader.
    • Place a hand underneath the memory card reader while unscrewing it so that it doesn't fall out.
    • Remove the CMOS battery cable from the motherboard.
  8. Dell Vostro V13 Disassembly: étape 8, image 1 de 1
    • Using a small plastic opening tool, gently lift and remove the two antenna cables from the wireless card.
    • Unscrew the one tiny screw securing the wireless card.
    • The wireless card should pop up.
    • Gently slide the card forward to remove it.
  9. Dell Vostro V13 Disassembly: étape 9, image 1 de 2 Dell Vostro V13 Disassembly: étape 9, image 2 de 2
    • Remove all six screws from the motherboard.
    • Unscrew the two PH00 screws from the cooling fan.
    • Gently lift the motherboard upward and then slide it forward to remove.
    • Be extremely careful with the motherboard!
  10. Dell Vostro V13 Disassembly: étape 10, image 1 de 1
    • Push the two metal clips on either side of the RAM outward; the memory chip will pop up.
    • Pull the memory down from the slot to remove it.
  11. Dell Vostro V13 Disassembly: étape 11, image 1 de 1
    • Unscrew the four PH1 screws from the heatsink.
    • You may also need to remove the screw on the fan shroud.
    • Pull the heatsink and the fan upward to remove both.
11 autres ont terminé cette réparation.
Kevin Dookharan
Membre depuis le 08/23/12
386 Réputation
1 tutoriel rédigé
2 commentaires de tutoriel
is the CPU removable?
Trevor Vuong - Réponse
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
Chris Yang - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 44
Total : 38,293
