Aller au contenu principal
Dell Vostro V130 Memory Module Replacement
Johnathan Hammond
Johnathan Hammond et 2 autres contributeurs
Dernière mise à jour le November 5, 2019
9 - 20 minutes
Modérée
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Outils
  1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: étape 1, image 1 de 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: étape 2, image 1 de 1
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: étape 3, image 1 de 1
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: étape 4, image 1 de 1
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Memory Module Replacement, Lift the Battery: étape 5, image 1 de 1
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Memory Module Replacement, LED Cover: étape 6, image 1 de 1
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  7. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: étape 7, image 1 de 1
    • Pull the LED cover toward the keyboard and remove it from the computer.
  8. Dell Vostro V130 Memory Module Replacement, Memory Module: étape 8, image 1 de 1
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  9. Dell Vostro V130 Memory Module Replacement: étape 9, image 1 de 1
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 02/28/18
45 216 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 8
Total : 345
