Aller au contenu principal
Dell XPS 15 9510 Speakers Replacement
Bethany Wright
Bethany Wright et 6 autres contributeurs
Dernière mise à jour le January 7, 2025
15 minutes
Modérée
Nécessite plus d'images
Audio issues or sound failure in the Dell XPS 15 9510 indicates that the speakers located on either side of the laptop may need replacement. There are no special skills involved in the removal of the speakers.
Before using this guide, make sure to review the troubleshooting page to ensure that the speaker doesn't have any driver or any other issues.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dell XPS 15 9510 Speakers Replacement, Lower Case: étape 1, image 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Speakers Replacement: étape 2, image 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Speakers Replacement: étape 3, image 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Speakers Replacement, Speakers: étape 4, image 1 de 3 Dell XPS 15 9510 Speakers Replacement, Speakers: étape 4, image 2 de 3 Dell XPS 15 9510 Speakers Replacement, Speakers: étape 4, image 3 de 3
    • Remove the 4 pieces of black tape holding the speaker wire in place.
  5. Dell XPS 15 9510 Speakers Replacement: étape 5, image 1 de 2 Dell XPS 15 9510 Speakers Replacement: étape 5, image 2 de 2
    • Remove the four 2.5 mm screws holding the speakers in place using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Speakers Replacement: étape 6, image 1 de 2 Dell XPS 15 9510 Speakers Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Lift the black tape that covers the power supply pin plug.
    • Remove the plug using a small pair of tweezers. Be sure to not damage any wiring.
  7. Dell XPS 15 9510 Speakers Replacement: étape 7, image 1 de 1
    • Lift the speakers up from the securing pins.
  8. Dell XPS 15 9510 Speakers Replacement: étape 8, image 1 de 2 Dell XPS 15 9510 Speakers Replacement: étape 8, image 2 de 2
    • Begin removing the wire from the track on the computer body.
    • Now the speakers will be fully disconnected from the computer.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 autres ont terminé cette réparation.
Bethany Wright
Membre depuis le 07/13/23
439 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 2-1, Harley Summer 2023 Membre de l'équipe IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 28
Total : 283
