Aller au contenu principal
Dell XPS 15 9550 Keyboard Replacement
Zach Jones
Zach Jones et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
1 heure
Difficile
This guide walks through the replacement of the keyboard in a Dell XPS laptop. It also includes instructions to remove of all the components necessary to access the keyboard.
Make sure to have a safe location to store all of the small screws while completing this guide, as the screws are very small and easy to lose.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dell XPS 15 9550 Keyboard Replacement, Back/Underside Panel: étape 1, image 1 de 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Keyboard Replacement: étape 2, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 2, image 2 de 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Keyboard Replacement: étape 3, image 1 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 3, image 2 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 3, image 3 de 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Keyboard Replacement, RAM: étape 4, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement, RAM: étape 4, image 2 de 2
    • There are 2 separate RAM sticks.
    • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
    • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
  5. Dell XPS 15 9550 Keyboard Replacement: étape 5, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 5, image 2 de 2
    • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
  6. Dell XPS 15 9550 Keyboard Replacement, Wireless Card: étape 6, image 1 de 1
    • With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
    • Set the screw and metal holder aside.
  7. Dell XPS 15 9550 Keyboard Replacement: étape 7, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 7, image 2 de 2
    • Gently lift up each of the antennas (3) to disconnect them from the wireless card.
    • These are similar to a coat button, the antennas snap on and snap off.
  8. Dell XPS 15 9550 Keyboard Replacement: étape 8, image 1 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 8, image 2 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 8, image 3 de 3
    • With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
    • The wireless card has been successfully removed!
  9. Dell XPS 15 9550 Keyboard Replacement, Cooling Fan(s): étape 9, image 1 de 1
    • Use the Small Plastic Spudger to carefully disconnect the white connector from the black port.
  10. Dell XPS 15 9550 Keyboard Replacement: étape 10, image 1 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 10, image 2 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 10, image 3 de 3
    • Use the Phillips #00 Screwdriver to remove the two 4 mm long screws.
    • The location of the 2 screws is different on each fan.
    • The left fan screw locations are circled in red.
    • The right fan screw locations are circled in orange.
  11. Dell XPS 15 9550 Keyboard Replacement: étape 11, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 11, image 2 de 2
    • With the screws removed, lift up on the fan and remove it from the laptop.
  12. Dell XPS 15 9550 Keyboard Replacement, Battery: étape 12, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement, Battery: étape 12, image 2 de 2
    • Use a Philips #00 Screwdriver to remove the seven 3 mm long screws from the perimeter of the battery.
    • Each screw is labeled "M2X4" with an arrow pointing to the screw.
  13. Dell XPS 15 9550 Keyboard Replacement: étape 13, image 1 de 1
    • Gently lift up on the backside of the battery.
  14. Dell XPS 15 9550 Keyboard Replacement: étape 14, image 1 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 14, image 2 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 14, image 3 de 3
    • Firmly grasp the black connector on both sides.
    • Carefully pull the connector towards the battery, to release the connector and the battery from the laptop.
  15. Dell XPS 15 9550 Keyboard Replacement, Motherboard: étape 15, image 1 de 3 Dell XPS 15 9550 Keyboard Replacement, Motherboard: étape 15, image 2 de 3 Dell XPS 15 9550 Keyboard Replacement, Motherboard: étape 15, image 3 de 3
    • The touchpad has two ZIF connectors at the bottom of the motherboard. Use a flat plastic tool to lift the tabs (see picture 2) and gently pull the ribbon cables free.
    • When re-assembling, make sure the connectors are set straight and square before closing the tabs.
  16. Dell XPS 15 9550 Keyboard Replacement: étape 16, image 1 de 1
    • Pull this Monitor connector out by its plastic edges
  17. Dell XPS 15 9550 Keyboard Replacement: étape 17, image 1 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 17, image 2 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 17, image 3 de 3
    • Remove the single Phillips screw to take off this plate and reveal the connector underneath.
    • Pull up the black strap with the plastic spudger, and use your fingers to gently but firmly pull straight up.
  18. Dell XPS 15 9550 Keyboard Replacement: étape 18, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 18, image 2 de 2
    • Pull up on the plastic edges to remove the indicated connector at the bottom right of the motherboard.
  19. Dell XPS 15 9550 Keyboard Replacement: étape 19, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 19, image 2 de 2
    • This connector in the top left might be taped in two places. Simply pull up to loosen the tape, and use the plastic edges of the connector to pull it out. Have some tape on hand for reassembly, as the tape might have lost its adhesive backing.
  20. Dell XPS 15 9550 Keyboard Replacement: étape 20, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 20, image 2 de 2
    • With all mounted components removed, unscrew the motherboard Phillips-head screws.
  21. Dell XPS 15 9550 Keyboard Replacement, Keyboard: étape 21, image 1 de 1
    • Remove the 14 #00 Phillips screws from the perimeter of the keyboard.
  22. Dell XPS 15 9550 Keyboard Replacement: étape 22, image 1 de 1
    • Remove 6 exposed #00 Phillips screws from the center of the keyboard.
  23. Dell XPS 15 9550 Keyboard Replacement: étape 23, image 1 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 23, image 2 de 3 Dell XPS 15 9550 Keyboard Replacement: étape 23, image 3 de 3
    Outil utilisé dans cette étape :
    • Use small tweezers to peel back the covers for the remaining 9 #00 Phillips screws.
    • Remove the remaining screws.
    • Theses screws can be difficult to access. The flaps are glued down and need to be peeled back with a moderate amount of force.
  24. Dell XPS 15 9550 Keyboard Replacement: étape 24, image 1 de 2 Dell XPS 15 9550 Keyboard Replacement: étape 24, image 2 de 2
    • Unplug the keyboard from the laptop by flipping up the small ZIF tabs and pulling the ribbon cables straight out.
  25. Dell XPS 15 9550 Keyboard Replacement: étape 25, image 1 de 1
    • Gently remove the keyboard from the laptop.
Now you have successfully removed your keyboard. To reassemble your device, follow these instructions in reverse order.
7 autres ont terminé cette réparation.
Zach Jones
Membre depuis le 03/25/22
400 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-4, Harley Spring 2022 Membre de l'équipe IUPUI, Team 2-4, Harley Spring 2022
IUPUI-HARLEY-S22S2G4
3 membres
3 tutoriels rédigés
4 commentaires de tutoriel
Will this work with a Dell Precision 5520? I have noticed that these two laptops use many of the same components.
Bryan White - Réponse
This was an excellent guide! The entire process took me a full two hours. Most of the time was spent trying to figure out how to fix a broken antenna filament on the wifi card. See my note regarding that step. My daughter's laptop keyboard is now brand new and I was able to remove all the dog hair and dust at the same time!
Peter Moeykens - Réponse
This was super-helpful. I have an XPS 7590, and a few things were slightly different, but this guide matched my machine closely enough. I now have a fully working machine with a new keyboard. Thanks!
Brad Compton - Réponse
wonderfully written & diagrammed guide, thank you internet friend!
admin admin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 26
30 derniers jours : 183
Total : 9,694
