Aller au contenu principal
Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement
Seth York
Seth York et 7 autres contributeurs
Dernière mise à jour le May 7, 2024
5 - 10 minutes
Très facile
Découpez pour améliorer
The following guide will show how to remove the volume control and screen lock buttons from the Digitac Jazz Ultratab C725 for replacement.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: étape 1, image 1 de 3 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: étape 1, image 2 de 3 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: étape 1, image 3 de 3
    • Locate the four 3.5 mm Phillips screws holding the silver back plate and the screen together. There are two screws on the top and two screws on the bottom.
    • Using the Phillips #00 Screwdriver, remove all four screws.
    • ● Remove the screws with the least amount of force possible to avoid damage to the threads. If thread damage occurs, screw removal will become more difficult.
  2. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: étape 2, image 1 de 3 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: étape 2, image 2 de 3 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: étape 2, image 3 de 3
    • Flip your device so that the long side without the buttons faces you.
    • Insert the Plastic Opening Tool between the silver back plate and the screen about one inch from the corner of the device on either side.
    • Using the Plastic Opening Tool, pry open the screen until it unsnaps from the back plate.
    • Work your way down the edge of the device, unsnapping all locations where the screen meets the silver back plate.
    • Go around the corners with the Plastic Opening Tool and unsnap additional snap-in locations as necessary.
    • Once the screen is loose, pull it towards you, then lift it to prevent damage to the buttons on the other side of the device.
  3. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: étape 3, image 1 de 3 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: étape 3, image 2 de 3 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Using a pair of tweezers, poke the square plastic piece between each of the buttons that connect them together. Each button has a plastic piece between their gaps.
    • While poking the square piece in, simultaneously push it upward to release it.
    • After releasing the first one, use the pair of tweezers, and do the same with the second one. This should free all buttons from the device.
    • Once the buttons are free, use the set of tweezers to grab the buttons and pull them out.
Seth York
Membre depuis le 01/20/15
355 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 11-6, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 11-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G6
2 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 305
