Aller au contenu principal
Dymo LabelManager 160 Wheelhead Replacement
Matthew Jenkins
Matthew Jenkins et 9 autres contributeurs
Dernière mise à jour le January 13, 2025
20 - 30 minutes
Modérée
If your Dymo LabelManager 160 is not properly printing from Dymo D1 Label Cassettes, the wheelhead which unspools the cassettes may be not functioning. This guide leads you through the process of opening up the LabelManager and changing the wheelhead. Keep in mind that the device has loose parts.
Before you begin, make sure that your device is turned off and the battery is removed.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Dymo LabelManager 160 Wheelhead Replacement, Batteries: étape 1, image 1 de 1
    • Place the device face-down to access the battery compartment.
  2. Dymo LabelManager 160 Wheelhead Replacement: étape 2, image 1 de 1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. Dymo LabelManager 160 Wheelhead Replacement, Keyboard: étape 3, image 1 de 1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. Dymo LabelManager 160 Wheelhead Replacement: étape 4, image 1 de 2 Dymo LabelManager 160 Wheelhead Replacement: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. Dymo LabelManager 160 Wheelhead Replacement: étape 5, image 1 de 1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. Dymo LabelManager 160 Wheelhead Replacement: étape 6, image 1 de 3 Dymo LabelManager 160 Wheelhead Replacement: étape 6, image 2 de 3 Dymo LabelManager 160 Wheelhead Replacement: étape 6, image 3 de 3
    • Gently remove the rubber keyboard from the device.
  7. Dymo LabelManager 160 Wheelhead Replacement, Wheelhead: étape 7, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the three 1.1 mm screws from the circuit board.
  8. Dymo LabelManager 160 Wheelhead Replacement: étape 8, image 1 de 1
    • Lifting the circuit board, use a Phillips #1 screwdriver to remove the two 1.2mm screws from under the circuit board.
    hoe verwijder je de display
    aslan - Réponse
  9. Dymo LabelManager 160 Wheelhead Replacement: étape 9, image 1 de 2 Dymo LabelManager 160 Wheelhead Replacement: étape 9, image 2 de 2
    • Proceed to lift the excess device components until the rollerblade is visible.
  10. Dymo LabelManager 160 Wheelhead Replacement: étape 10, image 1 de 1
    • With the device components exposed, gently lift the wheelhead out of the label maker.
2 autres ont terminé cette réparation.
Matthew Jenkins
Membre depuis le 01/27/16
262 Réputation
2 tutoriels rédigés
Équipe
4 commentaires de tutoriel
Group 9: Over all looks great. Pictures are great quality and hand placement in pictures. The circles and arrows should all be red. The only time the color changes is if there are different steps within a single picture.
Zachary Parker - Réponse
thank you for the procedure, i mis one screen in the procedure how to detach display?
aslan - Réponse
Guide does not properly address or account for parts that will simply fall out if you proceed with this course. Gears, springs, plastic bits, metal rods. I had a pile of seven or eight unknown bits, plus the plastic gears.
No photos of the gearing, or the levers that hold tension on the label ribbon. These are the parts will fall out.
All I’ve managed to do is take apart and reassemble, only to have pieces that are now out, who knows where they go. Device now gives me a label jam error when reassembled. Have no clue how the tensioner should be oriented.
Gonna move on and buy a new label maker now. Thanks for the frustration ifixit.
Christopher Warren - Réponse
Same sad story ! I am not able to reassemble the device...
alexandreliban -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 64
Total : 4,895
