Aller au contenu principal
EVGA x17 Scroll Wheel Replacement
Sydney Puett
Sydney Puett et 4 autres contributeurs
Dernière mise à jour le December 27, 2023
30 - 40 minutes
Modérée
If your EVGA x17 gaming mouse wheel doesn’t seem to register any movement, use this guide to replace the scroll wheel.
A scroll wheel is usually made of hard plastic with a rubber cover and located in between the left and right mouse clickers. A scroll wheel is intended for scrolling on a device. An unresponsive scroll wheel may be caused by a faulty USB port or incorrect mouse settings. Please refer to the troubleshooting page to explore the alternatives. This issue could also be caused by a build up of dirt or dust.
Click here to visit our guide on how to disassemble and clean the mouse.
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. EVGA x17 Scroll Wheel Replacement, Scroll Wheel: étape 1, image 1 de 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Scroll Wheel Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Scroll Wheel Replacement: étape 3, image 1 de 1
    • Remove the weight chamber cover.
  4. EVGA x17 Scroll Wheel Replacement: étape 4, image 1 de 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
  5. EVGA x17 Scroll Wheel Replacement: étape 5, image 1 de 2 EVGA x17 Scroll Wheel Replacement: étape 5, image 2 de 2
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Scroll Wheel Replacement: étape 6, image 1 de 1
    • Carefully slide middle section out.
    • Remove smaller sized cross head screws from piece labeled AZAC001-A V1.0.
  7. EVGA x17 Scroll Wheel Replacement: étape 8, image 1 de 1
    • Pull the transistor from the side of the mouse wheel.
  8. EVGA x17 Scroll Wheel Replacement: étape 9, image 1 de 1
    • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
    • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
  9. EVGA x17 Scroll Wheel Replacement: étape 10, image 1 de 2 EVGA x17 Scroll Wheel Replacement: étape 10, image 2 de 2
    • Remove scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue).
Sydney Puett
Membre depuis le 09/13/23
599 Réputation
3 tutoriels rédigés
Équipe
1 commentaire de tutoriel
Is there a wheel that can be purchased that will fit or can be modified to fit for the replacement.
Ronald Winfrey - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 17
30 derniers jours : 85
Total : 1,648
