Aller au contenu principal
Epson Powerlite 460 Filter Replacement
Korinna Curry
Korinna Curry et 4 autres contributeurs
Dernière mise à jour le June 21, 2022
4 minutes
Facile
This guide demonstrates how to remove and replace the air filter in your Epson PowerLite 460.
A filter keeps the dust and debris out of the device in order for the device to stay clean. Overheating can occur if the air filter is damaged or clogged, which can cause the device to not run properly. If so, replace or clean the filter.
Review the troubleshooting guide before replacing the filter. Other factors can cause overheating in the Powerlite 460.
  1. Epson Powerlite 460 Filter Replacement, Filter: étape 1, image 1 de 1
    • Orient the device with the projection window on top with the name of the device right side up.
  2. Epson Powerlite 460 Filter Replacement: étape 2, image 1 de 1
    • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
  3. Epson Powerlite 460 Filter Replacement: étape 3, image 1 de 2 Epson Powerlite 460 Filter Replacement: étape 3, image 2 de 2
    • Open the air filter cover by pulling the top down and away from the device.
  4. Epson Powerlite 460 Filter Replacement: étape 4, image 1 de 2 Epson Powerlite 460 Filter Replacement: étape 4, image 2 de 2
    • Pinch the air filter cover handle and gently pull the filter away from the device
    • This may take a small amount of force.
Korinna Curry
Membre depuis le 04/06/22
268 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 194
