Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Fan Blade Arm Replacement
Ricardo Ledesma Hernandez
Ricardo Ledesma Hernandez et 3 autres contributeurs
Dernière mise à jour le 2 juin 2022
1 - 2 heures
Facile
A besoin de meilleures images
Use this guide to replace the broken blade arm of a ceiling fan. A broken ceiling fan can reduce the comfort of your home, and it might make you utilize your home’s air conditioner (AC) more. A working ceiling fan will save money and potentially reduce greenhouse gases that hurt the earth.
Before using this guide, make sure you know where the circuit breaker is located and turn it off for safety reasons. A few necessary tools are needed, and no prior knowledge is required.
Ce dont vous avez besoin
  1. Fan Blade Arm Replacement, Fan Blade Arm: étape 1, image 1 de 3 Fan Blade Arm Replacement, Fan Blade Arm: étape 1, image 2 de 3 Fan Blade Arm Replacement, Fan Blade Arm: étape 1, image 3 de 3
    • Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
  2. Fan Blade Arm Replacement: étape 2, image 1 de 2 Fan Blade Arm Replacement: étape 2, image 2 de 2
    • Unscrew the finial (cover at the bottom of the glass globe). Then unscrew the hex nut and remove the rubber washer. This will allow the globe to be easily removed.
  3. Fan Blade Arm Replacement: étape 3, image 1 de 3 Fan Blade Arm Replacement: étape 3, image 2 de 3 Fan Blade Arm Replacement: étape 3, image 3 de 3
    • Remove lightbulbs to avoid damage when removing light pan. Then, remove all three fitter plate screws. This will cause the light pan to hang from the electrical wires.
  4. Fan Blade Arm Replacement: étape 4, image 1 de 2 Fan Blade Arm Replacement: étape 4, image 2 de 2
    • Disconnect single pin connectors to finish removing light fixture from fan.
  5. Fan Blade Arm Replacement: étape 5, image 1 de 2 Fan Blade Arm Replacement: étape 5, image 2 de 2
    • Remove the three screws from the fitter plate. This will allow the plate to easily be separated from the fan.
  6. Fan Blade Arm Replacement: étape 6, image 1 de 3 Fan Blade Arm Replacement: étape 6, image 2 de 3 Fan Blade Arm Replacement: étape 6, image 3 de 3
    • Remove the two screws securing the broken blade arm. Then separate the broken component from the fan.
  7. Fan Blade Arm Replacement: étape 7, image 1 de 3 Fan Blade Arm Replacement: étape 7, image 2 de 3 Fan Blade Arm Replacement: étape 7, image 3 de 3
    • Replace the broken blade arm on the fan blade. There are two components that are placed on either side of the blade and secured together with screws.
2 autres ont terminé cette réparation.
Équipez-vous pour vos futures réparations
Voir tous les produits
Équipe
4 commentaires de tutoriel
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
Maria Franco - Réponse
I am as well and harbor breeze and Lowe's are absolutely no help!
Brandy Broussard - Réponse
I’m looking for the same thing CANT find it anywhere I need the arm
Lisa - Réponse
Where can I find an exact replacement.
Darrell Resler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 60
Total : 8,635
