Aller au contenu principal
Fitbit Blaze Display Frame Replacement
Adrian Borrego
Adrian Borrego et un autre contributeur
Dernière mise à jour le February 4, 2018
15 minutes
Facile
Would like to replace your damaged or worn out metal ring around your device? This guide will show you how to remove and replace the metal ring that holds the LCD screen in place.
Ce dont vous avez besoin
Outils
  1. Fitbit Blaze Display Frame Replacement, Wristband: étape 1, image 1 de 2 Fitbit Blaze Display Frame Replacement, Wristband: étape 1, image 2 de 2
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze Display Frame Replacement: étape 2, image 1 de 1
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze Display Frame Replacement: étape 3, image 1 de 3 Fitbit Blaze Display Frame Replacement: étape 3, image 2 de 3 Fitbit Blaze Display Frame Replacement: étape 3, image 3 de 3
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
  4. Fitbit Blaze Display Frame Replacement, Display Frame: étape 4, image 1 de 3 Fitbit Blaze Display Frame Replacement, Display Frame: étape 4, image 2 de 3 Fitbit Blaze Display Frame Replacement, Display Frame: étape 4, image 3 de 3
    • Locate the pin behind the second wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
    • Remove wristband.
3 autres ont terminé cette réparation.
Adrian Borrego
Membre depuis le 02/20/17
2 242 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S3-G3, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 membres
15 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 24
Total : 11,172
