Aller au contenu principal
Fix a motherboard with failed NVIDIA graphics chip
Pilo
Pilo et un autre contributeur
Dernière mise à jour le July 24, 2020
Aucune estimation
Très difficile
Tutoriel réalisé par la communauté
  1. Fix a motherboard with failed NVIDIA graphics chip, Battery: étape 1, image 1 de 3 Fix a motherboard with failed NVIDIA graphics chip, Battery: étape 1, image 2 de 3 Fix a motherboard with failed NVIDIA graphics chip, Battery: étape 1, image 3 de 3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. Fix a motherboard with failed NVIDIA graphics chip, RAM Shield: étape 2, image 1 de 2 Fix a motherboard with failed NVIDIA graphics chip, RAM Shield: étape 2, image 2 de 2
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
  3. Fix a motherboard with failed NVIDIA graphics chip, Upper Case: étape 3, image 1 de 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  4. Fix a motherboard with failed NVIDIA graphics chip: étape 4, image 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  5. Fix a motherboard with failed NVIDIA graphics chip: étape 5, image 1 de 1
    • Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
  6. Fix a motherboard with failed NVIDIA graphics chip: étape 6, image 1 de 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  7. Fix a motherboard with failed NVIDIA graphics chip: étape 7, image 1 de 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  8. Fix a motherboard with failed NVIDIA graphics chip: étape 8, image 1 de 3 Fix a motherboard with failed NVIDIA graphics chip: étape 8, image 2 de 3 Fix a motherboard with failed NVIDIA graphics chip: étape 8, image 3 de 3
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
    • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
    • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
  9. Fix a motherboard with failed NVIDIA graphics chip: étape 9, image 1 de 2 Fix a motherboard with failed NVIDIA graphics chip: étape 9, image 2 de 2
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
    • Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
    • Remove the upper case.
  10. Fix a motherboard with failed NVIDIA graphics chip, Optical Drive: étape 10, image 1 de 1
    • Use the flat end of a spudger to disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  11. Fix a motherboard with failed NVIDIA graphics chip: étape 11, image 1 de 2 Fix a motherboard with failed NVIDIA graphics chip: étape 11, image 2 de 2
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive.
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
    • Lift the optical drive up and out of the computer.
  12. Fix a motherboard with failed NVIDIA graphics chip, Logic Board: étape 12, image 1 de 1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  13. Fix a motherboard with failed NVIDIA graphics chip: étape 13, image 1 de 1
    • Disconnect the iSight and display data cables from the logic board by sliding them straight back out of their connectors, removing tape as necessary.
  14. Fix a motherboard with failed NVIDIA graphics chip: étape 14, image 1 de 1
    • Disconnect the eight indicated connectors by placing a spudger beneath the wired side of each one and lifting up.
    • Use care when disconnecting some of the smaller connectors. A forceful prod with the spudger may accidentally break them off the logic board.
  15. Fix a motherboard with failed NVIDIA graphics chip: étape 15, image 1 de 1
    • Remove the foam bumper from the top of the right hinge of the display.
  16. Fix a motherboard with failed NVIDIA graphics chip: étape 16, image 1 de 1
    • Remove the silver 9.5 mm T6 Torx screw securing the ground loop in the display data cable to the casing.
  17. Fix a motherboard with failed NVIDIA graphics chip: étape 17, image 1 de 1
    • Remove the single black 6 mm T6 Torx screw securing the upper portion of the logic board to the lower case.
  18. Fix a motherboard with failed NVIDIA graphics chip: étape 18, image 1 de 1
    • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
  19. Fix a motherboard with failed NVIDIA graphics chip: étape 19, image 1 de 1
    • Remove the following 15 screws:
    • One 4.4 mm black Phillips screw to the right of the ram slot.
    • Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • If you leave the five uppermost orange screws in place, the heatsink/pipes come out effortlessly, still mounted onto the main board. That way its thermal connection is retained, and you won't need to reapply thermal paste as instructed two steps below.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
  20. Fix a motherboard with failed NVIDIA graphics chip: étape 20, image 1 de 2 Fix a motherboard with failed NVIDIA graphics chip: étape 20, image 2 de 2
    • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the left fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the left fan up.
    • Place the left fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
    • Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    • Remove the right fan from the computer.
  21. Fix a motherboard with failed NVIDIA graphics chip: étape 21, image 1 de 2 Fix a motherboard with failed NVIDIA graphics chip: étape 21, image 2 de 2
    • Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
    • Pull the power cable connector parallel to the face of the logic board.
    • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
    • If you detached the heatsink from the motherboard two steps above, you'll have to clean off and replace the old thermal compound from the chips on the back of the logic board. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
  22. Fix a motherboard with failed NVIDIA graphics chip, Just go on with given link...: étape 22, image 1 de 2 Fix a motherboard with failed NVIDIA graphics chip, Just go on with given link...: étape 22, image 2 de 2
    • Thanks to http://www.laptoprepair101.com/fix-lapto...
    • It fixed a MacBook Pro 15-Inch A1260 (Early 2008)
    • I have applied some liquid flux underneath the chip. Artikelnr. 472-345-30-L eclipse-dortmund.de (via Amazon)
Pilo
Membre depuis le 05/19/15
73 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 95
Total : 2,123
