Aller au contenu principal
Google Pixel 3a XL Midframe Replacement
Taylor Dixon
Taylor Dixon et 5 autres contributeurs
Dernière mise à jour le April 3, 2025
5 - 10 minutes
Facile
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
This guide is a pre-requisite step for other Pixel 3a XL guides. It describes the process of removing the midframe between the screen and the rest of the phone’s internals.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Google Pixel 3a XL Midframe Replacement, Midframe: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Remove the following 4.3mm screws:
    • 14 silver T3 Torx screws
    • 2 black T3 Torx screws
    • Due to manufacturing tolerances, a T4 Torx driver may fit better into these T3 screws.
  2. Google Pixel 3a XL Midframe Replacement: étape 2, image 1 de 3 Google Pixel 3a XL Midframe Replacement: étape 2, image 2 de 3 Google Pixel 3a XL Midframe Replacement: étape 2, image 3 de 3
    • The midframe is still held in place by plastic clips.
    • Insert an opening pick into the seam along the bottom of the phone.
    • Slide the pick along the seam to release the clips holding the midframe to the rest of the phone.
  3. Google Pixel 3a XL Midframe Replacement: étape 3, image 1 de 3 Google Pixel 3a XL Midframe Replacement: étape 3, image 2 de 3 Google Pixel 3a XL Midframe Replacement: étape 3, image 3 de 3
    • Slide the opening pick along the left and right edges of the phone to release the midframe clips there.
    • Once the clips along the bottom of the phone are separated, the flat edge of the opening pick should be enough to separate the rest of the clips.
    • Lift up the bottom edge of the midframe but don’t completely remove it yet. The midframe is still connected to the phone by a fragile cable.
  4. Google Pixel 3a XL Midframe Replacement: étape 4, image 1 de 2 Google Pixel 3a XL Midframe Replacement: étape 4, image 2 de 2
    • Use a spudger to pry up and detach the proximity sensor cable from the motherboard.
  5. Google Pixel 3a XL Midframe Replacement: étape 5, image 1 de 1
    • Remove the midframe from the phone.
  6. Google Pixel 3a XL Midframe Replacement: étape 6, image 1 de 2 Google Pixel 3a XL Midframe Replacement: étape 6, image 2 de 2
    • During reassembly, align the top edge of the midframe with the top of the phone, then use a spudger to carefully press the proximity sensor cable connector onto its socket.
    • This takes a bit of patience and finesse. Once you have the connector aligned, you can also use a finger to gently press the connector onto the socket.
Taylor Dixon
Membre depuis le 06/26/18
70 046 Réputation
94 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 7
Total : 90
