Aller au contenu principal
HP 15-d076nr RAM Replacement
Amy Weed
Amy Weed et 3 autres contributeurs
Dernière mise à jour le April 21, 2017
5 minutes
Facile
This guide details how to replace the RAM on an HP 15-d076nr. If your laptop is slow, this may be the guide for you.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. HP 15-d076nr RAM Replacement, RAM: étape 1, image 1 de 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces away from you.
  2. HP 15-d076nr RAM Replacement: étape 2, image 1 de 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  3. HP 15-d076nr RAM Replacement: étape 3, image 1 de 2 HP 15-d076nr RAM Replacement: étape 3, image 2 de 2
    • Carefully pry the middle panel up using a plastic spudger or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  4. HP 15-d076nr RAM Replacement: étape 4, image 1 de 1
    • Locate the RAM in the exposed area.
  5. HP 15-d076nr RAM Replacement: étape 5, image 1 de 3 HP 15-d076nr RAM Replacement: étape 5, image 2 de 3 HP 15-d076nr RAM Replacement: étape 5, image 3 de 3
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
  6. HP 15-d076nr RAM Replacement: étape 6, image 1 de 1
    • Remove the RAM.
Amy Weed
Membre depuis le 01/12/17
577 Réputation
5 tutoriels rédigés
Équipe
Oakland University, Team 2-2, Ruskiewicz Winter 2017 Membre de l'équipe Oakland University, Team 2-2, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G2
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 13
Total : 613
