Aller au contenu principal
HP Compaq 6710b Power Button Panel Replacement
Khulan Orgil
Khulan Orgil et 2 autres contributeurs
Dernière mise à jour le June 23, 2015
5 minutes
Modérée
Outils incorrects
Remove the power button panel from above the keyboard.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: étape 1, image 1 de 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: étape 1, image 2 de 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: étape 1, image 3 de 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: étape 2, image 1 de 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: étape 3, image 1 de 2 HP Compaq 6710b Power Button Panel Replacement: étape 3, image 2 de 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: étape 4, image 1 de 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: étape 5, image 1 de 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: étape 6, image 1 de 3 HP Compaq 6710b Power Button Panel Replacement: étape 6, image 2 de 3 HP Compaq 6710b Power Button Panel Replacement: étape 6, image 3 de 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
4 autres ont terminé cette réparation.
Khulan Orgil
Membre depuis le 04/14/15
1 171 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 4-2, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 17
Total : 3,432
