Aller au contenu principal
HP Compaq 6910p Processor Replacement
Tyler Fricks
Tyler Fricks et 4 autres contributeurs
Dernière mise à jour le December 14, 2017
20 minutes
Modérée
In this guide, we will illustrate how to remove and replace the processor of this device. Required tools include one Phillips screwdriver, one T9 Torx screwdriver, Arctic Silver Thermal Paste, and thumbs of course. Because the processor is difficult to find, patience will be required as well.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Compaq 6910p Processor Replacement, Processor: étape 1, image 1 de 2 HP Compaq 6910p Processor Replacement, Processor: étape 1, image 2 de 2
    • Turn the laptop upside down.
    • Remove the fourteen 1.5 cm Phillips's #1 screws.
    • Remove the battery.
    • Remove three 0.3 cm Phillips #1 screws in the battery compartment.
  2. HP Compaq 6910p Processor Replacement: étape 2, image 1 de 3 HP Compaq 6910p Processor Replacement: étape 2, image 2 de 3 HP Compaq 6910p Processor Replacement: étape 2, image 3 de 3
    • Slide the tabs upward to release the keyboard
    • Lift up the keyboard
    • Disconnect the cables attaching the keyboard to the laptop by lifting up the release tabs.
    • Use a spudger if you're having trouble lifting up the tabs.
  3. HP Compaq 6910p Processor Replacement: étape 3, image 1 de 1
    • Remove the upper frame of the laptop
    • This part is difficult, so use a spudger if you're having trouble removing the frame.
  4. HP Compaq 6910p Processor Replacement: étape 4, image 1 de 3 HP Compaq 6910p Processor Replacement: étape 4, image 2 de 3 HP Compaq 6910p Processor Replacement: étape 4, image 3 de 3
    • Loosen the four 1.5 cm Phillips #1 screws indicated in red.
    • Remove the heat sink to reveal the processor.
  5. HP Compaq 6910p Processor Replacement: étape 5, image 1 de 1
    • Lift up the processor carefully to remove
7 autres ont terminé cette réparation.
Tyler Fricks
Membre depuis le 10/22/15
528 Réputation
5 tutoriels rédigés
Équipe
Montana Tech, Team 3-2, Shirk Fall 2015 Membre de l'équipe Montana Tech, Team 3-2, Shirk Fall 2015
MTUM-SHIRK-F15S3G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 35
Total : 4,662
