Aller au contenu principal
HP Compaq C700 Keyboard Replacement
Taylor Johansen
Taylor Johansen et 4 autres contributeurs
Dernière mise à jour le December 10, 2018
15 minutes
Modérée
In this guide, you will learn how to remove the keyboard of the HP Compaq C700 laptop.
Ce dont vous avez besoin
Outils
  1. HP Compaq C700 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Keyboard Replacement: étape 2, image 1 de 3 HP Compaq C700 Keyboard Replacement: étape 2, image 2 de 3 HP Compaq C700 Keyboard Replacement: étape 2, image 3 de 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Keyboard Replacement: étape 3, image 1 de 1
    • Gently lift up and remove the keyboard.
Taylor Johansen
Membre depuis le 10/20/16
690 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 membres
6 tutoriels rédigés
2 commentaires
er zijn 3 schroeven aan het keyboard
marcel - Réponse
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
Blackblur610 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 822
