Aller au contenu principal
HP Compaq nc8430 LCD Screen Replacement
Corey Nickerson II
Corey Nickerson II et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
30 minutes
Modérée
A besoin de meilleures images
Nécessite plus d'images
Étapes manquantes
This guide will provide information on how to replace the LCD screen if you ever experience black out screen issues.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. HP Compaq nc8430 LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 LCD Screen Replacement: étape 2, image 1 de 1
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 LCD Screen Replacement: étape 3, image 1 de 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
  4. HP Compaq nc8430 LCD Screen Replacement, LCD Screen: étape 4, image 1 de 1
    • Remove the four 1.2mm Phillip #1 screws circled.
    • The laptop may have rubber covers over the screws,. Remove them using a pointed tool to pry them out.
  5. HP Compaq nc8430 LCD Screen Replacement: étape 5, image 1 de 2 HP Compaq nc8430 LCD Screen Replacement: étape 5, image 2 de 2
    • Pry up the plastic screen cover with the pry tool.
    • Once a corner of the plastic screen cover is lifted, slide the pry tool around the entire screen until the screen is completely lifted from the base.
  6. HP Compaq nc8430 LCD Screen Replacement: étape 6, image 1 de 1
    • Remove the 1.2 Phillips screws circled.
  7. HP Compaq nc8430 LCD Screen Replacement: étape 7, image 1 de 1
    • Remove the four 1.2mm Phillip screws circled.
  8. HP Compaq nc8430 LCD Screen Replacement: étape 8, image 1 de 1
    • Gently lift the monitor, from the base of the laptop.
    • The laptop will still be connected to the monitor wires located at the bottom of the screen.
  9. HP Compaq nc8430 LCD Screen Replacement: étape 9, image 1 de 2 HP Compaq nc8430 LCD Screen Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    • Locate the video cable wires.
    • Gently remove the video cables from the sensor board with tweezers.
  10. HP Compaq nc8430 LCD Screen Replacement: étape 10, image 1 de 1
    • All cables should be disconnected from the sensor board. Remove the eight 2mm Phillip screws attaching the bezel to the side of the monitor.
    • Attach the bezel to the new replacement screen.
Corey Nickerson II
Membre depuis le 03/20/17
111 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team S13-G4, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S13-G4, Bennett Spring 2017
TTU-BENNETT-S17S13G4
5 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Could you please charge it using USB.
Cato Nicolai Lund - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 863
