Aller au contenu principal
HP Elite x2 G1 1012 Speaker Replacement Guide
Hanif Norhisham
Hanif Norhisham et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
10 - 15 minutes
Modérée
If the speaker produce buzzing, crackling sound or not operational, there might be a problem with your speaker. This guide will help you go through the process of replacing the faulty speakers.
Before going through the replacement process, make sure your tablet is turned off and not connected to the power cord.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Elite x2 G1 1012 Speaker Replacement Guide, Speakers: étape 1, image 1 de 2 HP Elite x2 G1 1012 Speaker Replacement Guide, Speakers: étape 1, image 2 de 2
    • Detach keyboard from the screen.
  2. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 2, image 1 de 1
    • While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
    • The screws were not available on our device, so we do not know what kind of screwdriver to use.)
  3. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 3, image 1 de 3 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 3, image 2 de 3 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 3, image 3 de 3
    • Use a suction cup to remove the screen panel.
  4. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 4, image 1 de 3 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 4, image 2 de 3 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Detach flex cable from motherboard using tweezers.
  5. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 5, image 1 de 1
    • Unplug the battery wire attached to the motherboard using tweezers.
  6. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 6, image 1 de 3 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 6, image 2 de 3 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 6, image 3 de 3
    • Remove two 2.7 mm screws using the Phillips #0 screwdriver.
  7. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 7, image 1 de 2 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 7, image 2 de 2
    • Unplug the speaker wire attached to the motherboard.
  8. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 8, image 1 de 2 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 8, image 2 de 2
    • Detach the left speakers.
  9. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 9, image 1 de 2 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 9, image 2 de 2
    • Detach the two stickers highlighted from right speaker.
  10. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 10, image 1 de 2 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 10, image 2 de 2
    • Detach the right speaker cables from the motherboard using tweezers.
  11. HP Elite x2 G1 1012 Speaker Replacement Guide: étape 11, image 1 de 2 HP Elite x2 G1 1012 Speaker Replacement Guide: étape 11, image 2 de 2
    • Detach the right speaker.
2 autres ont terminé cette réparation.
Hanif Norhisham
Membre depuis le 05/22/19
571 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G5, Harley Summer 2019 Membre de l'équipe IUPUI, Team S1-G5, Harley Summer 2019
IUPUI-HARLEY-SU19S1G5
4 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 29
Total : 774
