Aller au contenu principal
HP EliteBook 2540p
HP EliteBook 2540p
lunar
lunar et un autre contributeur
Dernière mise à jour le November 15, 2023
1 - 7 minutes
Facile
A besoin de meilleures images
Tutoriel réalisé par la communauté
Pretty bad pictures, taken on my cheap webcam, sorry!
If you have the same device and are willing to take better photos that'd be great.
------------------------------------------------------------------------------------------------Reason for making this: Saw no page for the HP 2540p, so I am posting it here. Also didn't see many YouTube videos showing this.
Keep in mind, that this is my first "contribution."
  1. HP EliteBook 2540p, Taking the Battery Out.: étape 1, image 1 de 3 HP EliteBook 2540p, Taking the Battery Out.: étape 1, image 2 de 3 HP EliteBook 2540p, Taking the Battery Out.: étape 1, image 3 de 3
    • Power off the computer if you have it on, and flip it over.
    • Pull both things on the side of the battery.
    • While still pulling both of them back, take out the battery, it should just slip out.
  2. HP EliteBook 2540p, Removing cover and installing drive/RAM: étape 2, image 1 de 3 HP EliteBook 2540p, Removing cover and installing drive/RAM: étape 2, image 2 de 3 HP EliteBook 2540p, Removing cover and installing drive/RAM: étape 2, image 3 de 3
    • While Still on the back, look for a plastic cover that says "HP 3D DriveGuard." (AKA. the longest cover)
    • Unscrew it, there are 3 Philips screws on it.
    • Personally, I do not have a drive in it right now, but you will need a 1.8-inch drive to fit it into the laptop. Plug the SATA Drive into the connector.
    • For the ram pull the two gray things a bit and then take out or put in the ram at an angle.
Put the cover back on and screw it in, then you can put the battery back in as well.
lunar
Membre depuis le 10/02/23
85 Réputation
1 tutoriel rédigé
Équipe
Master Techs Membre de l'équipe Master Techs
Community
327 membres
1 676 tutoriels rédigés
1 commentaire de tutoriel
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/165266235415
jacques_06
jacques_06 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 46
Total : 429
