HP EliteBook 840 G7 Trackpad Replacement
Introduction
Passez à l'étape 1This guide is to instruct you in the proper removal and replacement of the Trackpad in an HP EliteBook 840 G7. Use this guide if your computers Trackpad stops working.
Ce dont vous avez besoin
Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
Den Phillips #1 Schraubenzieher benutzen um die fünf schrauben auf der Rückseite des Laptops zu entfernen
Remove the back cover to expose the hardware.
Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
Remove the connector that connects the battery to the motherboard.
Lift up the battery with you hands or tools.
1 commentaire de tutoriel
laptop treckpad automatically get clicked while speaker produced a sound
Auf den Rücken drehen
Luis-Oliver Bota - Réponse
